‎2024-07-10 07:28 PM
I will be grateful if you help to solve the problem. The wall, which is a multi-layer structure, disappears on the plan and is not displayed in 3D
‎2024-07-10 10:08 PM
Could you please provide more information or screenshots? Is the layer turned on in both the plans and 3D view? Is the wall drawn on the correct level?
‎2024-07-22 11:53 AM
The layers is turned on in both views
‎2024-07-23 02:55 AM
Has the wall been placed on a different storey?
If you copy the settings (pipette) of one of the existing walls and place a new wall somewhere, can you see that?
‎2024-07-23 05:54 PM
I had 2 floors, I removed the first one and after that the outer walls disappeared. More precisely, the walls are disappearing, just like this multi-layered structure
‎2024-07-23 06:27 PM
Any other multi-layer construction is displayed on the plan and in 3D
‎2024-07-23 06:37 PM
reasons this happens:
if it is in all views except plan, the element is duplicated and the redundant elements "cancel" each other out by building material priority
if it happens even in plan view, it is:
-hidden by layer
-it is wireframe in 3d (by layer)
-overridden by graphic override or renovation
-hidden by design options
try deleting the wall in 3d with all layers/renovation status showing. If deleting the wall makes a wall appear, you had redundant walls.
there is a 'check for duplicates' feature, but I've never put it to much use.
‎2024-07-24 03:21 AM
If you have deleted a storey, then all elements on that storey will have been deleted as well.
If you place a new wall in that floor plan, does it show?
‎2024-07-24 03:08 PM
If it's the same multi-layered structure as the walls that disappear, it doesn't show. If another one then I can see it on plan and 3d
‎2024-07-24 03:14 PM
I checked it, everything is all right
