2026-05-14 03:54 AM
I would like to create a floor covering that is 4x4 ceramic tile. That is task one.
May be an shape
Then I would like to depress the tile to where the drain is and add a drain at that location
Help is appreciated
Operating system used: Mac Apple Silicon 29
2026-05-14 04:40 AM
Here's a video I did last year on using the Mesh Tool for shower floors (and the column tool for drains).
https://youtu.be/t2sk34zIClI?si=8uLMk9muZOOGq1r5
a month ago
I was hoping this could be handled like other modeling software. It required you to set a point in the top of the slaband then to depress it. And you could do multiple like for a trench drain
a month ago
The CI Essentials Tiled Shower object. It only allows for a square drain though...
I usually just do as Jared has shown...
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 5900X | 32GB | GTX2080TI |
a month ago
Same. Most of the time we do as Jared shows as most of the time is the only process needed
a month ago
that is how the Mesh solution works in the video I referenced.
a month ago
Is CI essentials part of Graphisoft now or a add on service.
a month ago
Unsure, though they do not seem to have a lcf or libpack for AC28 or AC29. They have the individual objects for download though, and they are supposedly on BIMComponents but that site appears to have just become a portal for BIMObject...
Ling.
a month ago
You can create a sloped shower floor using the Composites and Roof tool. To cut away the lower portion of the composite's filler material, simply use Solid Element Operations. This workaround can be time-consuming but ensures precise construction.
4 weeks ago
Thank-you as I will look into this. If you have a saved what you created above? Would you provide it here to be shared
