Link
Tip: Don’t be controlled by the Wall Reference Line
Hi all
Another tip from our blog, this time on wall reference lines!
bim6x.com/blog/don%E2%80%99t-be-controlled-wall-reference-line
Be sure to subscribe!
Link.
5 Replies 5
Roderick's comment in the post was interesting.
I used to have that facility on a shortcut, but can't find the control any more - I thought it had been dropped when Archicad changed the reference line button.
Roderick says it's on the edit menu, but I don't know where. Can you help?
Link
Yes, you can still access them!
Link.
Not in my version!
Keith,
Your Work Environment may have been migrated from an earlier ARCHICAD version.
If you change the "Current menu Structure" option to "All commands in alphabetical order", you will find those commands.
Or, if you switch to the "Standard Shortcuts" Shortcut Scheme it will contain them.
Yes, that's the case.
Thanks, Laszio
