2005-08-24 02:56 AM
2005-08-30 09:44 PM
2005-08-30 09:52 PM
Roolio wrote:If in the middle of a Drag command you hit "Alt" or "Ctrl-Alt", Drag turns into Drag a Copy or Drag Multiple Copies.
All of the staff (15) in our office have a problem intermittantly when using the drag command. Archicad decides that we want to use the 'drag a copy' command instead. And it takes a bit of fiddling around to get rid of it, ie not just hitting the CTRL key, but Escaping out of the the command completely and re-starting it.
I wish this would not happen.
Roolio
2005-08-30 10:39 PM
2005-08-30 10:55 PM
Tom wrote:Tom
2005-08-30 11:03 PM
s2art wrote:OH!!!Tom wrote:Tom
It's actually "Ctrl" or "Ctrl-Alt" isn't it, but that doesn't seem to be the problem Roolio is having. As I read it, "drag a copy" is occurring when not wanted (or invoked) and can't be un-invoked (i.e. hitting "Ctrl" again to get back to simple Drag command).
2005-08-30 11:14 PM
2005-08-31 11:32 AM
Link wrote:and it drives me nuts
That's right and if for example, you use ctrl+' to fit in window during your drag, that ctrl will ~inadvertently~ make a copy.![]()
s2art wrote:not on a mac it's notTomWaltz wrote:It's actually "Ctrl" or "Ctrl-Alt" isn't it, ...
2005-08-31 02:53 PM
2005-08-31 03:17 PM
Keith wrote:
I also like using the 'Alt' or 'Option-Alt' (on a MAC) to drag a copy or multiple copies, because it works equally well with MIRROR and ROTATE.
BUT (and it's a big BUT), in Plotmaker I always move things out of position when I meant to copy them, because the the 'Alt' and 'Option-Alt' don't work!
Anybody else suffer from this?
