To 'Drag a copy' or not to 'Drag a copy'
All of the staff (15) in our office have a problem intermittantly when using the drag command. Archicad decides that we want to use the 'drag a copy' command instead. And it takes a bit of fiddling around to get rid of it, ie not just hitting the CTRL key, but Escaping out of the the command completely and re-starting it.
I wish this would not happen.
Roolio
15 REPLIES 15
Are your alt keys sticky?
Never seen this myself.
TomWaltz
Roolio
If in the middle of a Drag command you hit "Alt" or "Ctrl-Alt", Drag turns into Drag a Copy or Drag Multiple Copies.
You can tell by the small "+" or "++" by the cursor. Pressing Alt or Ctrl-Alt toggles this on and off.
Our office found it so useful, no on actually uses the "Drag a copy" command any more.
Tom Waltz
yes, the drag and drop is a great feature
Tom
It's actually "Ctrl" or "Ctrl-Alt" isn't it, but that doesn't seem to be the problem Roolio is having. As I read it, "drag a copy" is occurring when not wanted (or invoked) and can't be un-invoked (i.e. hitting "Ctrl" again to get back to simple Drag command).
TomWaltz
s2art wrote:
Tom
OH!!! I'm sorry, I totally misread that!
Tom Waltz
Link
That's right and if for example, you use ctrl+' to fit in window during your drag, that ctrl will ~inadvertently~ make a copy.
Keep in mind that the ctrl and ctrl+alt modifiers are toggles, so hitting them again will disable them.
Link.
__archiben
and it drives me nuts
s2art wrote:
It's actually "Ctrl" or "Ctrl-Alt" isn't it, ...
not on a mac it's not !
cheers
~/archiben
b e n f r o s t
I also like using the 'Alt' or 'Option-Alt' (on a MAC) to drag a copy or multiple copies, because it works equally well with MIRROR and ROTATE.
BUT (and it's a big BUT), in Plotmaker I always move things out of position when I meant to copy them, because the the 'Alt' and 'Option-Alt' don't work!
Anybody else suffer from this?
Achille Pavlidis
i think you can only use the "drag a copy" command in PM, not the multiple copies drag...
Mac OSX 13.6.6 | AC 27 INT 5003 FULL
