2021-01-30 09:36 PM
2021-01-31 07:35 PM
2021-02-01 09:23 PM
2021-02-01 11:02 PM
Giovannino60 wrote:You do not type anything in text. You press the keystroke that you want to be the shortcut.
What should I write here? If I write crtl + 9, is it not written? Can I only type F1-F2 ...? I tried to write F1 and then nothing is enabled ...
Thank you
2021-02-02 05:42 AM
2021-02-02 06:38 AM
Giovannino60 wrote:
When I write ctrl+9, it comes out, already assigned (although ctrl+9 shaving it now does not work, that is, it does not activate anything), I still proceed?
2021-02-03 08:08 AM
2021-02-03 09:35 AM
Giovannino60 wrote:So when you select something in plan and press CTRL+9 (without the + of course), you should see this dialogue box.
Given that I did not proceed to change the settings. However, with ctrl+9 "Elevate" does not work, if I write ctrl+9 nothing changes. Compared to Archicad 19, keyboard settings are no longer there, such as ctrl+2, ctrl+3, etc.?
2021-02-03 07:04 PM
2021-02-04 02:38 AM
