2006-05-29 12:42 PM
2006-05-29 05:22 PM
2006-05-29 05:51 PM
2006-05-30 01:12 AM
2006-05-30 02:00 AM
One annoying thing that AC10 doesn't show that AC 9 did was when you float your mouse over the Toolbox icons it would show you the name of the Tool plus what it's shortcut is but in AC 10 it only shows you the name of the the Tool but no shortcut.This is not actually correct. AC10's tooltips still shows all the keyboard shortcuts, it's just that the default (INT) Shortcut Scheme does not include many Toolbox shortcuts. Hover over the Polyline tool to see.
2006-05-30 10:27 AM
This is not actually correct. AC10's tooltips still shows all the keyboard shortcuts, it's just that the default (INT) Shortcut Scheme does not include many Toolbox shortcuts. Hover over the Polyline tool to see.Well I have shortcuts assigned to most of the Tools on the Toolbar but they aren't being displayed when I float my mouse over the icons.
2006-05-30 01:27 PM
I wonder if there is a difference between the US version and the European version?I wouldn't have thought so. It's usually the same program with localization for different regions. I'm running just the INT (817) at the moment, as I recently uninstalled the US version.
2006-05-30 03:51 PM
2006-05-30 07:25 PM
fuzzytnth3 wrote:Yep, here too. Gotta say that I much prefer the Toolbox to the Tool palette. Smaller, simpler and without the Selection/Design/Document divisions which I find a little patronizing (if I'm using the wall tool in a detail isn't that documenting?).
Weird thing I have found is that the smaller Toolbox Tools pallette the name of the tool and the shortcut appear but still don't work for the fullsize pallette.
2006-05-30 08:30 PM
Chazz wrote:You can use the Wall Tool in a Detail Window?fuzzytnth3 wrote:Yep, here too. Gotta say that I much prefer the Toolbox to the Tool palette. Smaller, simpler and without the Selection/Design/Document divisions which I find a little patronizing (if I'm using the wall tool in a detail isn't that documenting?).
