F4 shortcut not working
I recently moved offices, and am using AC10 on a PC (came from AC11 on a Mac).
I've noticed a few annoying differences, but the main one is that F4 does not work (ie opening the 3D window of marquee or selection)
In work environment> shortcuts, I cant find the menu command to re-assign it.
If i press F3 when I've got a marquee or a selection, it shows everything.
thanks
thanks
Right mouse click on your selection/marquee and choose the option from the context menu.
You will also see there what keyboard shortcut is assigned.
Probably will be F5 which is the default for viewing selection/marquee.
Your other office must have altered the default shortcut.
