‎2006-07-07
11:13 PM
‎2023-05-25
05:14 PM
Rubia Torres
‎2006-07-09 04:03 AM
ctaylor wrote:there is. first ensure that each of your contour lines in turn are grouped, or a single polyline. next, draw a mesh around their outside border, setting the appropriate general levels in the mesh tool settings.
is there a way to create a mesh from the lines?
‎2006-07-09 04:10 PM
~/archiben wrote:I have found that most DWGs produce meshes that are much too complex. I prefer to quickly trace the contours with the spline tool and then use those to modify the mesh.
...space-click each of the lines in turn to create new nodes on the mesh...
‎2006-07-11 07:48 AM
ctaylor wrote:When Archicad xref's a dwg file its 2d, so if the contours were created using LDD it would not matter, the 3d info is not passed on. So you can create a mesh using the spline and follow each contour line and assign it the particular elevation. If you are getting the information from a surveyor that can send you points or change the dwg to a dxf on a regular basis, Architerra is a very wise investment. Not only that I think the price dropped recently
What is the best way to convert 2d topography lines, imported from a dwg file, into a 3d archicad10 model? If I elevate each topo line to the correct elevation, is there a way to create a mesh from the lines?
thanks
chris
‎2006-07-11 08:17 AM
‎2006-07-11 09:42 AM
