Eman
Tracing
If I want to trace an elevation of a house from a photo that I take myself, what is the best way to do it? I am asking because the photo it is hard to take it exactly with 90° angles or straight lines, so I always end up drawing it instead or tracing it!
Eman / Draftsman
Works at an Architects Company using ArchiCad 21
Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 3.19 GHz, 8.00 GB, 64-bit operating system, x64-based processor
5 Replies 5
Just here : https://blog.graphisoftus.com/graphisoft/align-view
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
Lingwisyer
Guru
You could try using the straightening tool in something like Photoshop or Lightroom to correct your perspective. "Filter => Adaptive Wide Angle" in Photoshop. Draw a line linking two points, right click and define as vertical or horizontal.
Ling.
Eman
Thanks very much for your replies and help!
Eman / Draftsman
Just a tip on taking the photo. If you're able to and have the gear, get as far back from the building as you can and use your highest zoom lens to fill the frame. This will produce a much more "flattened" perspective with the least amount of foreshortening. The closer you get and wider the angle of the lens, the more disproportionate items become in relation to one another.
Rex Maximilian, Honolulu, USA - www.rexmaximilian.com
ArchiCAD 28/29 (user since 3.4, 1991)
16" MacBook Pro; M4 Max (2024), 48GB RAM, 1 TB SSD, 32-Core GPU
Apple Vision Pro w/ BIMx
Creator of the Maximilian ArchiCAD Template System
Steve Jepson
This looks like it would be very useful for tracing things
