Tracker Won't Go Away
There is a toggle to turn the tracker box on and off, but it doesn't turn the box off when you're just hovering over elements. It only turns off the tracker when you are creating or editing elements. How can I get the Tracker Box completely turned off?
2 Replies 2
TomWaltz
That's not the tracker, thats the new Element Info box. It does not have an on/off swicth that I know of. The closest I know of would be to crank up its time delay setting in your Work Environment.
Tom Waltz
__archiben
it does . . .
Work Environment>Selection and Element Information>Enable Element Information Pop-up (Info Tag)
or you could put the time delay to something as large as 100 seconds. that way it only pops when you're selecting (arrow tool or hold down shift) and press TAB . . .
~/archiben
b e n _ f r o s t
