‎2006-05-30 08:04 AM
Matthew wrote:I'm puzzling over this myself. I thought the point of the tracker was to eliminate the coordinate box. I'm for anything that reduces the stuff on the screen to a minimum. I've found shortcuts for most of the other things on the coordinate box, but it seems the only way to switch from absolute to relative coordinates in the tracker is to go deep into Work Environment menus and uncheck a box. That's a deal killer for me. So I've kept the coordinate box, but then why have the tracker? Is there a shortcut I'm missing here?
.... But I still haven't given up the control and coordinates palettes, and I not sure that I will any time soon. They still do things that I haven't found substitutes for in the guidelines and tracker.
‎2006-05-30 08:24 AM
‎2006-05-30 03:56 PM
David wrote:David:
‎2006-05-30 07:16 PM
‎2006-05-30 07:26 PM
David wrote:FWIW, I've just found a keyboard shortcut that toggles the tracker between absolute and relative coordinates. In the keyboard shortcuts menu, put the available commands in alphabetical order and look for "Relative coordinates in tracker."
‎2006-05-30 10:31 PM
David wrote:......or you could have just told everyone what it was.....
‎2006-05-30 10:45 PM
s2art wrote:It doesn't have one by default. You have to do it yourself.David wrote:......or you could have just told everyone what it was.....
(p.s. I don't know, 10 arrives June 12 here).
‎2006-05-30 11:57 PM
‎2006-05-31 06:47 AM
Matthew wrote:I had some funny issues when using surveyor units and the tracker was incorrectly entering the angles. I had to physically click in the coordinates box to get the angles entered correctly. I need to do some mores testing to see if it is a persistent problem...
AFAIK you are right. The tracker is still not a full replacement for the coordinates palette. If it really could do all the same things only easier, I would be happy to switch, but as I said I'm keeping the coordinates palette for now. What I'm not sure of yet is whether the two can peacefully coexist.
‎2006-05-31 10:29 PM
