I have something interesting going on; when I use the Label Tool I am able to make beautiful leaders with spectacular arrowheads, etc. The problem occurs with text - no text input box appears!
The only way I can make text appear is if I select the just-created label (which shows a tiny text box with only one space in it), press the label tool, then edit the one space contained in the text box by adding text.
This problem occurred after I used the label tool and found there was default text entered that I did not want - I went into the tool dialogue, deleted the default text, and the problem began.
I've gone through every aspect of the label tool dialogue box, with no results.
Because of this problem, I updated AC to the most current version yesterday - the problem is still there.
Thanks for whatever help/insites you guys have to offer.
Dennis
	Dennis Glynn AIA
ArchiCAD-64 23 3003 USA FULL
x64 Clone PC w/Intel(R) Core i7-4790 CPU @ 3.60GHz, 3601 Mhz, 4 Cores, 8 Logical Processors
NVIDIA Quadro K620
16.00 GB RAM
Win 10 Pro x64 based PC
