ā2006-05-30 08:04 AM
Matthew wrote:I'm puzzling over this myself. I thought the point of the tracker was to eliminate the coordinate box. I'm for anything that reduces the stuff on the screen to a minimum. I've found shortcuts for most of the other things on the coordinate box, but it seems the only way to switch from absolute to relative coordinates in the tracker is to go deep into Work Environment menus and uncheck a box. That's a deal killer for me. So I've kept the coordinate box, but then why have the tracker? Is there a shortcut I'm missing here?
.... But I still haven't given up the control and coordinates palettes, and I not sure that I will any time soon. They still do things that I haven't found substitutes for in the guidelines and tracker.
ā2006-08-08 01:00 AM
Brad wrote:they didn't - they've just turned everything off in protest!
How did they get the user angle constraint back? I miss it so...
But I do like the pre-selection highlight. I'm afraid to get you started though.like james i do use the surface selection highlight. i have it set to an un-obtrusive colour so that it doesn't bother me in a 2D window - its real benefit for me comes in the 3D window. however, in doing this i come to my dilemma (thanks to link for helping me figure this one out...): because surface selection highlight is on it prevents me from clicking 'through' an already selected surface to get to another element stacked over or under it. for example, if i have a text block over a slab element and my toolbox has the slab tool currently active, shift clicking over the text
I had the tracker on but during a Graphisoft recommended reset had it accidently default to off and didn't miss it for days. I never did turn it back on. Any supporters out there?i would support the tracker if it could replace the co-ordinates palette. i tried. i really tried. like a few others here i was party to the developer releases as far back as late last year. every time a new version was released for us to test i duly switched the tracker back on and the co-ords palette off . . . and every time i had to turn the co-ords palette back on in order to achieve something. and every time i (and others) told graphisoft what needed to be done to make the tracker worthwhile until i got sick of the sound of my own voice. the tracker
ā2006-08-08 10:44 AM
ā2006-08-08 11:31 AM
~/archiben wrote:Well now I know what a presure cooker must feel like at times.
graphisoft - i am very unhappy at having to use such long-winded flashy trash in order to get what was essentially a basic job for quick select in AC9 done. why did selection highlight have to break good, intuitive selection functionality? i'll tell you why: because true to form graphisoft found the job of building new features into existing ones too complicated and resorted to the simpler, cheaper, scissors-and-celloptape job of tacking something on the side. you cannot take advantage of just some aspects of the highlighting without switching over to an entirely new working method. the give . . . yet they also take away.
I had the tracker on but during a Graphisoft recommended reset had it accidently default to off and didn't miss it for days. I never did turn it back on. Any supporters out there?/. . . instead, like the whole selection debacle, it's just another half-implemeted feature that stands alone from (rather than complements) existing functionality.
~/archiben
ā2006-08-08 11:36 AM
ā2006-08-09 06:18 PM
ā2006-08-09 06:29 PM
ā2006-08-09 09:04 PM
ā2006-08-09 10:54 PM
ā2006-08-10 12:02 AM
