ā2008-08-02
05:41 PM
ā2023-05-26
02:47 PM
Rubia Torres
ā2008-08-02 06:17 PM
ā2008-08-03 05:45 AM
Karl wrote:Just to add to Karl's advice here, a quick way of selecting only 2D info using Find & Select is to remove all choices and just select 2D Types from the drop down.
If you added new information into model layers, so that you cannot use layer control to make the selection quick and easy, then you'll have to use Find & Select (etc) to select the 2D elements that were added to the section and then copy/paste.
