2022-05-29 10:24 AM - edited 2022-05-29 10:25 AM
I am trying to change a 2d symbol of an object. I added a transparent shape and put it above a table. Unfortunatelly it is only showing up in the tab where I change the symbol. When I load this symbol to the project, it stops being visible. How can I make this transparency visible in the project?
2022-05-30 03:22 AM - edited 2022-05-30 03:25 AM
Could you just do without the Fill? When you say "load into the project" is that the same project in which you made the modification or a different one? Did you override the previous object? If it is a different project, have you reloaded your libraries, given that you did not just save to the embedded library previously?
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
