Transparent Beams
Hi!
Does the beams look transparent in plan views? Why? Is there a way to correct this?
3 Replies 3
The beam tool doesn't have cover fills. Why? I don't know. I hardly use the beam tool because of it and instead use anything else to draw beams with. I think I used beams once for cutting holes, but otherwise it's usefulness is hampered by not being able to apply cover fills. Maybe someone can give a reason why to use beams (maybe for complex profile solutions) but I haven't needed them.
btw, there are beams in the object library that have cover fills. I use when I need actual beams.
David Maudlin
lfalcao:
Beams do not have cover fills, there is a thread and poll here:
Cover & Background Fills for Beams
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks!
So, it's better to use walls instead of beams. It also helps to correct the visualization in different levels of plans.
