Trim a wall to fit between two roofs?
Hi!
I am working on a project in which I would love to be able to trim a wall between two roofs, bot at bottom and top, but I can't figure out how to do it.
Is it even possible?
10 Replies 10
Aaron Bourgoin
highlight the wall and the two roofs and view them in the 3D window. highlight the wall and invoke Solid Element Operations. It will be the Target. Highlight the upper roof and make it the operator for a subtract with upward extrusion. Highlight the wall again and make it the target again. highlight the lower wall and do a subtract with downward extrusion.
hope that's clear.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.1 USA
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
Dontknow
Yes, it's possible.
You'll have to put your two roofs in a different layer and make the buttom roof a single plane roofs (if it's not already).
Here is how you can do it: video.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
Dontknow wrote:
You'll have to put your two roofs in a different layer ....
Not necessary
Aaron wrote:
highlight the wall and the two roofs and view them in the 3D window. highlight the wall and invoke Solid Element Operations. It will be the Target. Highlight the upper roof and make it the operator for a subtract with upward extrusion. Highlight the wall again and make it the target again. highlight the lower roof as operator and do a subtract with downward extrusion.
hope that's clear.
Fixed
Aaron Bourgoin
Thanks for catching that Stuart!
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
Dontknow
s2art wrote:
Not necessary
With this method it's necessary to use separate layers.
ArchiCAD 25.
Aaron Bourgoin
Dontknow wrote:
s2art wrote:
Not necessary
not necessary. there's a simpler way.
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
Dontknow
True, its's a simpler way.
My question:
I do it with two execute's, up and down, can it be done with one execute at once?
ArchiCAD 25.
Aaron Bourgoin
it requires two steps as it's two separate operations.
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
