2025-02-07
04:26 PM
- last edited on
2025-02-08
01:40 PM
by
Hello, I am renovating a large existing building. The survey shows walls at different angles and I want to know if there is a way around these corners. see below. I made a column in one instance then I tried a wall but I am not happy with the corners showing like that. Is there a way?
Solved! Go to Solution.
2025-02-10 02:58 AM
These walls are not connecting to each other?
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2025-02-10 02:58 AM
