12LKS202512
Connecting wall corners at odd angles
Hello, I am renovating a large existing building. The survey shows walls at different angles and I want to know if there is a way around these corners. see below. I made a column in one instance then I tried a wall but I am not happy with the corners showing like that. Is there a way?
LKS Associate Architect, Intel(R) Core(TM) i7-9700 CPU @ 3.00GHz 3.00 GHz, 16.0 GB, 64-bit operating system, Windows 11 Pro.
1 Solution
Lingwisyer
Guru
These walls are not connecting to each other?
Win11 | i9 10850K | 64GB | RX6600 Win11 | i9 11900K | 32GB | GTX2080TI
Go to post
1 Reply 1
Lingwisyer
Guru
