Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
Trim roofs with roofs?
I have 2 intersecting roofs, and bacause of the diferent pitches, and heights of each, i cant draw them the way i need, so i drew them overlapping, but now how can i trim one with the other?
2 REPLIES 2
Aussie John
can you show us a picture? You should be able to get the roofs to align to each other ( use the command click method) ie select a roof command click (mac) on the other roof edge and the roof edge will move to the exact meeting spot of the two roofs (repeat for the other side)
Cheers John
[/size]
1. Mark one of the roof.
2. Press CTRL and then leftclick on roofline that should connect to the marked roof. Release CTRL
3. Unmark the first roof
4. Mark the other roof
5. point 2 but with other roof.
I hope you understand my english.
/Tobias
