Trim to roof
I'm having troubles with trim to roof. If I have a rake wall that I used trim to roof on and decide to raise the pitch etc, how can I get the wall to trim again? I've tried to increase wall height but the wall does not respond to height increase, only height decrease.
Thanks, Jim
3 REPLIES 3
Link
Select the wall and edit it's settings. You will find an 'Undo Roof Trim' button under the Model tab.
Link.
Erika Epstein
This is a great place to use SEOs. Using SEOs establishes a relationship between the roof and wall; move the roof and the wall adjusts with it.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Stephen Dolbee
I use SEO's on all my gable ends. Then, even if your pitch changes, no need to re-do.
Steve
AC19(9001), 27" iMac i7, 12 gb ram, ATI Radeon HD 4850 512mb, OS 10.12.6
