Trim to specific roof
Hey, I have two roofs (as you can see in the pict). I need to trim selected walls to the market roof, but when I run trim to roof comand, it gets trimed to the bigger roof. Is there a way to set roof you wanna trim to? Thx in advance
1 Reply 1
David Maudlin
WhiteMan:
First, Suspend Groups so you can select one wall, then select the roof you want to cut the wall, then Trim to Roof.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
