Triming walls
Can you trim a wall to the stairs if the wall is not on top of the stairs. It is running alongside the stairs but will not trim with seo.
3 Replies 3
Solid element operations only trim elements that physically intersect. I always have a solid elements operations layer for keeping "operators" that can be used for trimming but never show in any views. Perhaps this would work for your needs.
thank you. i hadn't thought of that before but this is a great idea.
With the ArchiStair Add-on by Cigraph the SEO works with stairs.
