Trouble with Zones
Hello,
I am having trouble with my zones. I created the building and zoned the rooms. After saving it (and creating views, etc.) I tried making new zones but I keep getting 0 (zero) in the zone stamp for area.
What I noticed is that the Calculated Area (Zone Selection Settings>Area Calculation) is zero, whereas the other areas (Measured Net Area, Remaining Area, Measured Gross Area) are normal (Area Subtraction is zero).
Please help,
Thanks.
Darko.
11 REPLIES 11
Djordje
What is the zone height and what is the height the zones are reduced at?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Sorry. I just noticed that after creating a zone with 100% area reduction on, you cannot change this in the zone selection settings. You have to make the zone all over again with area reduction off.
Sorry 'bout stealing your time...
Hvala!
Its not working.... again.
Ok now. These are the settings I use to place the zone...
...and this is what I get after placing the zone and opening zone selection settings...
Zone height is 2,7, Reduction is at 2,0 and 1,0. (Length unit is meters...).
Djordje
Your reduction check box is at 100%; try uncheking that!
Nema na cemu,
Djordje
HP Omen
...but it wont let me. I go to the zone selection settings and uncheck it, but it does nothing. I update the zone and go to the same zone selection settings, and it is still cheked! (see attached pics in prior posts).
Anyway, what I noticed is that after I copy my project into another project map (story 1 to story 2 for example) the zones function as normal for some time. After some time (I havent noticed what triggers it) I get the 100% reduction again, and cannot turn it off.
Thanks for the help.
I've had trouble with Zone Settings (colors and zone stamps) staying through a send and recieve. Are you working in Teamwork and without exclusive access by any chance?
No. But it seems that the latest patch solved the problem. After patching it, it worked "as advertised"
Thanks for the help y'all!
