Trouble with Zones
Hello,
I am having trouble with my zones. I created the building and zoned the rooms. After saving it (and creating views, etc.) I tried making new zones but I keep getting 0 (zero) in the zone stamp for area.
What I noticed is that the Calculated Area (Zone Selection Settings>Area Calculation) is zero, whereas the other areas (Measured Net Area, Remaining Area, Measured Gross Area) are normal (Area Subtraction is zero).
Please help,
Thanks.
Darko.
11 Replies 11
Think Ill crash this party rather than start a new one....
I am setting up a drawing for building control, and want to display the occupant capacity and Building Control designation. This is linked to the floor area and so would like to display it within the zone info box. I can add it to the user defined list within the dialogue, can get this to show on the drawing / print??
Cheers
Matt
ArchiCAD 8.1R2
Djordje
If I understood correctly - you want to add new parameters to the existing zones? In that case you have to edit the zone stamp object that you are using and add the new parameters.
It would help if you posted a screenshot; regulations are usually location specific and therefore not all of us can understand what you are talking about ...
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
