CFS_Mike
Turn off snap to a point cloud
Is there any way to turn off snap just for the point cloud? The point cloud has so many dots, it's hard to work with. The only result from searching was an option that is not available on my input constraints and guides.
3 Replies 3
runxel
There is sadly no way directly. However I found the Design Options to be a quite nice workaround. (Use the "lock passive elements" option).
Funnily enough this even makes the experience better overall, since the DO panel can stay and is not modal like the layers dialog. 🤣 So switching a PC off and on is easy.
torben_wadlinger
You're title should not be "hero" instead it should be "fox".
(in Germany fox stands for a very, very smart person who is able to think outside the box)
SzecsodiBenjamin
Hi everyone,
I’ve run into this issue as well, and it would really be helpful if we could disable snapping to the points of the point cloud.
I’ve created a feature request about this on the wishlist.
You can support it with a vote at the following link:
Disable snapping to point cloud points
