‎2006-10-04 06:07 PM
‎2006-10-04 06:52 PM
‎2006-10-04 07:17 PM
‎2006-10-04 09:28 PM
‎2006-10-04 10:06 PM
Richard wrote:
It probably makes the most sense, then, to orient the models as orthogonally as possible to the sheet based on convenience, and have a separate file for each terrain, with the building model hotlinked into it.
‎2006-10-04 10:54 PM
PatriciaLeão wrote:Easy. Archicad will do it for you. You have the option when hotlinking to have angled objects, including text orientation, fixed or automatically adjusted. There is a checkbox for this. Look for this in the hotlink dialog box.
I "just" don't know how I could do it in order to also keep the text orientation correct...
‎2006-10-04 11:41 PM
Matthew wrote:
If you need some of the annotations to carry over from the building models they should still orient themselves properly (ie. not be upside-down) in the site plan. I usually carry minimal or no annotations from the building models into the site since it becomes redundant information and no one should be referring to a site plan to lay out partitions (or whatever) anyway.
‎2006-10-06 06:14 AM
‎2006-10-06 12:56 PM
