PatriciaLe_o
Turn the model... or not?
I'm working on a model, oriented with the north up. Normal... and I already got used on working in it like that. But to put the plans drawings on the sheets I have to turn ir somehow. My question is: HOW!?
1 - should I turn the sheet master? (but this way the plan's texts would not turn)
2 - should I turn the drawing at the layout? (the texts wouldn't turn either)
3 - should I turn the whole model!? (this way I wold have to get used to the north pointing left!)
I know that I cannot think with my old Autocad mind, but I wanted something similar to the UCS rotation... I could work on modelspace with one orientation and make the viewports on paperspace with another orientation...
Is it possible?
Patricia Leão
AC21 INT Full
MacOSHighSierra
12 Replies 12
I prefer to work on the model in the orientation that it will appear on the sheet and reset the north arrow accordingly. In cases where this is not possible or where sections of the plan are rotated in the layouts it is possible to rotate the text accordingly. I think that there are ways to do this in the layout/drawing but it may also be necessary to rotate some elements in plan. Since I align the plan and layouts 99.9% of the time I rarely have to deal with this.
PatriciaLe_o
Thanks for the super fast reply! But I guess that I'm in an odd situation. I think I'd resign to turn the model if it was only one model used in one terrain. But my case is: I have 10 house models that will fit in more than 300 terrains with irregular limits and of course, different sun orientations. So, if I keep the project the way I'd like to see on sheets, I'd have to turn every terrain and it´s seems a little "violent" to me. Any suggestion?
Patricia Leão
AC21 INT Full
MacOSHighSierra
It probably makes the most sense, then, to orient the models as orthogonally as possible to the sheet based on convenience, and have a separate file for each terrain, with the building model hotlinked into it.
Richard
AC26 (since AC6.0), Win10
PatriciaLe_o
For sure I'll have one file per terrain (the whole terrain measures 200ha, so I think I'd need a NASA computer to work with it!). I think that the most sense would be insert the models in the terrains, as modules, keeping the terrain orientation BUT be able to show the plans orthogonally on sheets... I "just" don't know how I could do it in order to also keep the text orientation correct...
Patricia Leão
AC21 INT Full
MacOSHighSierra
Your situation is easily handled. I have done this many times.
The buildings are each modeled and documented in their own file orthagonal to the screen with the model and drawings at the same orientation. The various buildings are then hotlinked into the site model (or models) which are independently documented.
If you need some of the annotations to carry over from the building models they should still orient themselves properly (ie. not be upside-down) in the site plan. I usually carry minimal or no annotations from the building models into the site since it becomes redundant information and no one should be referring to a site plan to lay out partitions (or whatever) anyway.
Easy. Archicad will do it for you. You have the option when hotlinking to have angled objects, including text orientation, fixed or automatically adjusted. There is a checkbox for this. Look for this in the hotlink dialog box.
Richard
PatriciaLe_o
Thank you again Matthew and Richard for helping me!
My idea was to carry everything from a complete model (I mean a detail phase project) so there will be lots of information.
My problem is not how to insert the model, rotating and keeping the text right... I've already used the feature on Place Hotlink box that Richard just mentioned. The problem, I think, is making the texts look right at a rotated view plan drawing in a layout.
I think I must be having problems on explaining myself, and I'm sorry I don't have print shots to post, because I'm still planning how I'm going to manage this huge project (for me, at least!) while modelling the houses final versions.
Patricia Leão
AC21 INT Full
MacOSHighSierra
Brad Elliott
I think 1 & 2 from your original message will give you the exact same result. Which can give you some text issues.
I think that the best way to insure that the drawings show the way you want them to on paper is to orient them that way while working on them. Are they 10 completely different plans? What I have done when they are similar is have them all oriented the same way on the drawings and let the North arrow fall where it may. It breaks convention but I find the contractors can understand the drawings better when they are all oriented the same when they are looking at them.
Mac OS12.6 AC26 USA Silicon
M1 Macbook Pro
Djordje
Patricia,
Take a look at the Modules topic:
http://archicad-talk.graphisoft.com/viewtopic.php?t=12786
The message by Eric Batte, quoted by Link, addresses just your situation.
HTH,
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
