Turned off wall surface function
Please see attached image. At some point I turned off the function that allows the wall surface setting to show, and no cannot remember how to turn it back on. Assistance will be greatly appreciated.
3 Replies 3
Activate the overide surfaces buttons
David Maudlin
Michael:
If you are referring to the vectorial hatching (fill) on the wall's surface, go to Elevation Settings > Model Display > Uncut Elements > Vectorial 3D Hatching. The Surface needs an associated Vectorial Hatching set under its Surface Settings.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
If you mean you have turned the INFO BOX off then you will find it in the WINDOWS > PALETTES menu.
Or you could re-apply your Work Environment to reset all palettes, toolbars, keyboard shortcuts, and many more settings all at once.
Or you can re-apply sections of the Work Environment such as just the Palette Schemes.
