Two towers with different story setting. HOW ?
My project has two seperate towers with different storey setting (one tower is 3.3 floor-ceiling height, the other is 4.5)
How can we resolve the issue of story level lines on section and elevation for each towers? Do it manually or is there another way ?
These two towers are in one file.
Please help.
Many thanks
4 Replies 4
Erika Epstein
Tran,
This has been much discussed here. One was is to save out each building as a library part and place it on the site. When the building changes, resave the it as a library part and the site file will update.
Another is to use modules. You need to save each floor as a separate module. Not as difficult as it sounds as you can set up a publisher set for this. The first time you place these modules in the site file you may have to do some vertical adjusting, easiest in a section. After that you are republishing the modules and then updating modules.
HTH
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Thanks for your hints. I've got an idea how to resolve it.
Ernest Atanasiu
please share with us your solution!
arch. ernest atanasiu
AC 10-29 INT/GER/FR on Win 11
Please NGUYEN Tran, post your solution on the forum.
