2006-05-17
03:50 PM
2023-05-25
05:01 PM
Rubia Torres
2006-05-17 04:48 PM
2006-05-19 08:41 AM
2006-05-19 10:32 AM
Gerald wrote:StairMaker does this.
Your solution is the one I would use if you want a perfect rectangle for the landing. I am pretty sure Stairmaker won't allow this. In the concrete stairs I do I use this room for the railings as they do the 180 deg. turn to still maintain minimum landing width.
2006-05-19 04:14 PM
Djordje wrote:As I recall StairMaker will not do a landing without some return at the upper flight. This is a real problem in the US since many residential stairs are L-shaped with square landings that are the same width as the stair in both directions. Yes the trim details are tricky, the balustrade requires easments (and perhaps volutes), and it is not legal for commercial stairs but it is a common condition that we can't easily model.Gerald wrote:StairMaker does this.
You can choose whether the last tread is on the top floor level or one riser below it.
2006-05-19 05:09 PM
Djordje wrote:I thought he was talking about the intermediate landing and not the top tread/riser. If you try to dial in 0 distance between the riser and the landing you will get an error. At least I have not been able to get it to work.
