Unable to Rename View Map Folders
Gerry Leonor
Was the option to rename a folder through the Right Click pop-up removed?
i don't like having the Properties Tab open all the time & it seems quicker with the Right Click pop-up option.
https://discord.gg/XGHjyvutt8
5 REPLIES 5
Curious.
The Rename command is there in the context menu even in AC17 so it was removed in AC18. I can't find a good reason why.
I will report this to Graphisoft.
Still cannot rename after installing the update, so it must be intentional
Just change in the properties below the view map
Link
You should be able to just click on the name and rename it right there too.
Link.
Eduardo Rolon
Link.
You should but it does not work.
Eduardo RolĂłn AIA NCARB
AC29 US/INT -> AC08
another Moderator
Csaba Kezer
Hi guys,
You are right, this should be working. The developers are investigating why this has happened in v18.
In the meantime - as Gerald already mentioned - you can rename the Folders from the Properties tab.
Best regards,
Csaba
Csaba Kézér
VP, Global Customer Support
