Unclean Wall Junctions
So I was drafting this bungalow in Archicad the other day and found that Archicad could not clean up this junction automatically. Although it seems that it tried to but it is still not how it should be. The wall is a composite and the priorities are correctly set. Is this a glitch in the software or am I going wrong with some settings.
Some of these intersections can be tricky and some you may not be able to fix correctly but have you tried changing the reference edge to the opposite side for one to two of the walls or perhaps all off them to the centre position?
Gerald Hoffman
“The simplification of anything is always sensational” GKC
Archicad 4.55 - 29-Latest USA
2024 M4 Max MacBook Pro-macOS 15.5 (128GB (16 Core CPU + 40 Core GPU)
David Maudlin
Miqdad:
In addition to Gerald's suggestion, you can try changing the Junction Order of the individual walls.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
