Undocumented Improvements in AC15
Link
Here is the beginning of a list of 'minor' fixes in AC15 that I was personally involved in. I hope that others may be able to add other undocumented improvements to it:
1. Mirroring text now mirrors the anchor point.
2. The Help menu search function is no longer case sensitive.
3. Fill Area Text's are transferable via the eyedropper/syringe.
4. Project North now accepts up to 4 decimals (when set in working units).
5. Right click on Layouts and Masters to edit their settings.
6. Module Save Options have a new display setting.
Link.
undefined
56 REPLIES 56
You still learn new things everyday!
But then this one is really AC15 (I hope): true projection of roofs including Custom Edge Settings.
JaredBanks
Mentor
Radial Distorted Fill is older than 15, but the button is now always visible. In 14 (And 13 I presume), the option only showed up if you exploded a circular wall that met all the criteria. Which as everyone knows only happens a few times per project.
Jared Banks, AIA
Shoegnome Architects
Yes, I will give you that one!
It's a shame with that option you now loose the ability to select a symbolic view of any rooflights placed. They are all projected as well.
On a related note - Where is the overhead linetype and pen for rooflights found now? I'm just seeing a solid line the same as the uncut portion.
Edit - Found it! For some reason you have to untick both 'Enable Object's Linetypes' & 'Enable Objects Pens' in the floorplan and section tab in the object settings. Seems counter-intuitive to me.
Is that undocumented?
Several New Feature videos on YouTube talk about it.
The Special Menu has been divided into two parts: 59 GDL Developer and 60 Special Menu. There is a new command 'Run Parameter Script of all Placed objects' and I can really use that!
The help has been expanded: this part is about the Element Listing Parameters in the Interactive Schedule
vfrontiers
vfrontiers wrote:
And for the love of all things good... please keep the TOOLBOX where I put it on a MAC! Every time I open ArchiCAD... it's bad enough that I have to move it back in place... but the darn thing resizes to the full height of the screen but is placed down 40 or 50 pxls so I have to drag it UP, resize it smaller, drag it down into place then drag it to fit the space I've left for it...
.... A little CHEESE to go with that WHINE!....
1. Crow tastes good!
2. It looks as thought GS DID fix this in AC15!
Duane
Visual Frontiers
AC25 :|: AC26 :|: AC27
:|: Enscape3.4:|:TwinMotion
vfrontiers
Laura wrote:
Master wrote:
another one, the Quick Layers toolbar can now be docked!
It may dock, but it's still not saved as one of the Palette settings in the Work Environment.
I find some STRANGITY here too... I ALWAYS want Quick Layers open and visible (and in the same place I leave it)...
Ea time I open up AC... it disappears..
But... If I open up a floating palette (like COMPLEX PROFILES) and edit and store... Voila, the quick layers palette has re-appeared in the center of my screen..
Duane
Visual Frontiers
fuzzytnth3
I get round this by making a toolbar for the Quick Layer and also TW commands and save that with my Work Environment. It then stays available at all times
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
vfrontiers
I just TOOLBAR'd the quick layers a couple of days ago... Doesn't look as nice, but the buttons are there...
I may do the same for TOOLBOX as my previous post about how it nows stays put was premature! Seems if I have it ONE tool wide and pretty much the height of the screen, it does stay in place... but tucked in 3 tools wide and short, it continues to plant in some random place each time I open a file!
Duane
Visual Frontiers
