‎2021-02-10
01:44 AM
‎2023-05-09
03:45 PM
Rubia Torres
‎2021-02-10 02:18 AM
Yvonne wrote:Short answer - no.
Is it possible to unify walls like you would lines into polylines?
‎2021-02-11 12:39 PM
However, if your walls are in a straight line (i.e. the reference lines appear to be in a continuous straight line), then you can use the EDIT menu > RESHAPE > MERGE WALLS command.Thank you, I have never noticed that before.
This will convert the multiple walls into one wall, but also change it to a 'Custom' complex profile wall.
You can simply then select it and change it back to a standard or composite wall type of your choosing.
