ā2004-06-15 02:37 AM
ā2004-06-17 05:36 PM
Tom wrote:I have encountered numerous instances where I was placing an element and I saw the dark check-mark cursor when I clicked, but upon closer inspection, it didn't grab the hotspot and my placed element was wrong. I've become so paranoid about this that I am now in the habit of zooming way in on hotspot areas for every click -- certainly a waste of time, but less of a waste that accidentally drawing something wrong. By the way, my cursor snap range is set to 3.
When it's zoomed in close, the actual points of the intersection of the lines or whatever it is do not stack up one on top of the other no matter what the settings are.
ā2004-06-17 05:57 PM
have encountered numerous instances where I was placing an element and I saw the dark check-mark cursor when I clicked, but upon closer inspection, it didn't grab the hotspot and my placed element was wrong. I've become so paranoid about this that I am now in the habit of zooming way in on hotspot areas for every click -- certainly a waste of time, but less of a waste that accidentally drawing something wrong. By the way, my cursor snap range is set to 3.That's what I'm talkin about. The checkmark really does not mean you are on that point. Wouldn't it be better to set your cursor snap range to 1. In my mind, that would give you the most accuracy. But no matter what I set the accuracy of the units and the pixels to, the same situation you noted occurs. It is quite aggravating and leads to a lot of redos of things.
ā2004-06-17 08:29 PM
Tom wrote:I find the default setting of three pixel snap range to be ideal (especially on a high res monitor). In all the work I have done, much of it very highly detailed, I have rarely had a problem with too many snaps too close together. I do occasionally have to zoom in to particularly complex areas, but these layers are usually turned off in smaller scale views and I am already working close in on the enlarged scales.have encountered numerous instances where I was placing an element and I saw the dark check-mark cursor when I clicked, but upon closer inspection, it didn't grab the hotspot and my placed element was wrong. I've become so paranoid about this that I am now in the habit of zooming way in on hotspot areas for every click -- certainly a waste of time, but less of a waste that accidentally drawing something wrong. By the way, my cursor snap range is set to 3.That's what I'm talkin about. The checkmark really does not mean you are on that point. Wouldn't it be better to set your cursor snap range to 1. In my mind, that would give you the most accuracy. But no matter what I set the accuracy of the units and the pixels to, the same situation you noted occurs. It is quite aggravating and leads to a lot of redos of things.
I am looking for the best settings to prevent this. Or is this an ArchiCad problem that will be there no matter what the settings are.
ā2004-06-17 10:30 PM
Matthew wrote:That's the weird part, this usually happens when there is only one possible snap.
...I have rarely had a problem with too many snaps too close together.
Matthew wrote:I thought of that, but my mouse setting is the least balistic of anybody's in the office. I also thought the 3-pixel snap range would help, but it doesn't seem to make much difference.
Very small snap distances (like 1 pixel) can have the problem that a twitchy mouse (or operator) can fall off the snap in the act of clicking, thus missing the node or edge by a small margin.
ā2004-06-18 12:39 AM
ā2004-06-18 12:44 AM
ā2004-06-18 12:47 AM
Jay wrote:Hmm, troubling. Seems like it is difficult to isolate. Are you all using pretty much the same equipment?
It seems to be spread around. I've talked to most of the users about this problem and they have all experienced it at one time or another.
ā2004-06-18 03:52 PM
ā2004-06-18 05:14 PM
Matthew wrote:The boxes are all Dell Precision 360s, but the RAM size, HD size, etc., vary slightly. There are at least two different video cards that I know of, but I'm not sure which machines they are in.
ā2004-06-18 10:41 PM
Tom wrote:ArchiCAD depends on precise feedback from the screen as to which pixel the mouse is pointing at when you click. Remember that making this whole GUI thing work properly is, as the programmers say, not trivial.
We are using a logitech keyboard and mouse. Maybe I'll try a switch. But how would those pieces of hardware screw up Archicad. Seems strange.
