ā2004-10-20
06:54 PM
- last edited on
ā2023-05-26
12:54 PM
by
Rubia Torres
ā2004-10-23 10:28 AM
Link wrote:link, link, link!
The consequence of these intersection priority numbers are important in Solid Element Operations. Lets say for example you use a white beam (or any other 3D non-wall element) to subtract a recess out of a brick wall. To make it a white recess, you would set the SEO subtraction so that the 'New Surfaces of Target will: Inherit Attributes of Operator'. However, if the layer of the beam has the same intersection priority number as the layer of the wall, the recess will still appear as brick. You will need to change the intersection priority number of one of them (say the beam) to get the recess to show up white.
ā2004-10-23 03:31 PM
Link wrote:Thanks for expanding on my brevity. You have just reminded me that I ran into this behavior with the SEOs a while ago (in 8.0 as I recall) and to me it seems a bug rather than a feature. Since the SEO has the ability to define the inheritance of material settings, the intersection priority is just an added annoyance.
They are VERY useful! To add to Matthew's post, some other important things to note are:
ā2004-10-23 06:25 PM
link, link, link!Of all the people....
where were you a couple of weeks ago when i was struggling over just this problem!
If this feature is documented, I never noticed it ...
You have just reminded me that I ran into this behavior with the SEOs a while ago (in 8.0 as I recall) and to me it seems a bug rather than a feature. Since the SEO has the ability to define the inheritance of material settings, the intersection priority is just an added annoyance.I agree with you on the annoyance issue Matthew! I don't see why we should have to allow for layer intersection priorities when doing solid ops, and (even though it is early on a Saturday morning), I can't see how
Overall the intersection priorities seem like a first draft solution to fixing the wall intersections. It is a further attempt to stretch the limited concept of layers to accommodate the organization of the virtual building.Me too!
I am hoping this improves as we go forward.
