Update Level dim w/ Gravity?
Tom Krowka
Have a slab upon which I placed a level dimension with Gravity to slab activated. I elevate the slab, I would think that the level dim. would change appropriately. It does not.
If I delete and place a new one, correct elevation shows up. This can't be right. How can I update the level dim once I change slab elevation.
Tom Krowka Architect
Windows 11, AC Version 26
Thomas@wkarchwk.com
www.walshkrowka.com
5 REPLIES 5
Tom Krowka
Part two of this issue....
Am trying to set level dim of the slab relative to altitude. The slab is set 8" above the setting of the altitude, which is set in climate data in the energy calculator. When I set the dim relative to altitude with gravity to slab, the dim always give me the altitude, not the altitude of the slab, which should be 8" more.
Am I missing the whole big picture here?
Thomas@wkarchwk.com
www.walshkrowka.com
David Maudlin
Tom:
Works here. When the Level Dimension is selected, does the Slab temporarily highlight to show that the Level Dimension is associate with the Slab? Are you on 15 or 16?
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Tom Krowka
Slab does not highlight, only the dim. Am using V 16, most current.
Thomas@wkarchwk.com
www.walshkrowka.com
David Maudlin
Tom:
If the Slab is not highlighting, then the Level Dimension is not associated to the Slab. You should recheck the Gravity setting before placing the Level Dimension.
Tom Krowka
Discovered my problem, and as usual a simple solution. Static dimension was checked on the level dialogue box. Duh!
Thomas@wkarchwk.com
www.walshkrowka.com
