Using cut plane for ghost plans in 10
Is anyone else using cut planes to show ghost stories in Archicad 10?
I'd like to show the walls in the story below on my framing plans. How do you show them below, but not on the current story?
Thanks for your help.
Hunter.
10 Replies 10
Thank you Tom. Your simple screenshot solved the issue. The overlay method, or hack as James put it, is completely redundant now, in my opinion.
Eric's right - plans should be thought of as cuts through the model, just like sections & elevations, although this example was more than a case of just showing the background with the current layer combination. We should be able to have a similar marked distant area to which we can assign a specific layer combination, model view combination, pen set, etc. It would beat the pants off this ridiculously cumbersome and over-complex cut plane thing.
Let's get a true BIM environment already!
Hunter.
