2016-10-0803:03 AM - last edited on 2023-05-2603:20 PM by Rubia Torres
I go into Options>Element Attributes>Fill Types, and the only Vectorial Fill option I have available is Drawing Title Block. Am I supposed to import these from somewhere?
I just want a basic grid pattern..
You can import Fills from another project using the Attribute Manager. Once Attribute Manager is open, you can open a template file (Applications > GRAPHISOFT > ARCHICAD 20 > Defaults > ARCHICAD > template files) and import as many Fills as you need. Another option is to open a template file in a new instance of ArchiCAD and copy and paste the Fills from the template file into your current project file.
David Maudlin / Architect www.davidmaudlin.com Digital Architecture AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
