Version 10 Windows?
I'm a little confused with the window hotspots on the library 10 windows, versus 9. On 9 I was able to pull the frame all the way to butt up against a wall, so that when I scaled the window, it was the exact width of the opening, or height. With 10, the hotspot of the window is almost the glass, so that the frame is put inside the wall, rather than sitting outside it, like a normal window should....am I doing something wrong? need help...
1 REPLY 1
It's hard to follow your description. A screen shot would help.
There should be a setting for "Show All Hotspots" (or something like that) under the window's custom 2D settings tab. That might help.
