Version 25 and woking with others using INT
Eric Milberger
I create my model in ver 25 here in the US.  I have Engineers and Architects that use 25 INT.
Can they work with me using their version?
Eric Milberger, Architect | Master Planner
5 REPLIES 5
Djordje
Yes, but make sure that you set a project library, since INT and US are not the same. Also, your 1st floor is ground floor in most of the rest of the world...
Once upon a time, a Canadian gentleman combined the US and INT libraries and added some stuff from other national versions that was useful for everyone... but that was a very long time ago. The hope that a global library will happen one day is still alive.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
The ACE Library! It was a great idea, but the volunteers didn't have the resources to keep it up version after version.
Given the increase in cross-border work, it becomes more necessary every day.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Djordje
Quite so, @vistasp...
Speaking of cross border work, I remembered our BIMCloud event in Dubai, where:
- BIMCloud was set up in Budapest by @Gabor Kovacs
- Mohannad and I were in Dubai, presenting and coordinating you guys
- Fadi was in Egypt
- you were in India
- @Gordana Radonic was in Novi Sad
- Marin Račić was in Rijeka
- Victor Arcos was in Colombian jungle, connecting via his mobile
We also wanted someone from Down Under, but the timing was wrong for them... and regretfully did not have anyone on Antarctica, just to cover all the continents 😄
and it all worked 🙂 Luckily, we had all used the INT version, so no library issues 😄
Djordje
HP Omen
Yup, I remember that event very well!
= v i s t a s p =
bT Square Peg
@Djordje that was probably the first time ever I used teamwork function! It was so exciting 🙂
Gordana Radonić
Community Manager
