Vertical Line/Wall
Eman
By mistake I changed a setting that I cannot find which one it is. I changed a setting that when I draw a vertical line or wall and then I enter the length, the dimensions that I enter goes into x coordinate and not in y coordinate. So the line/wall always rotate to an angle.
Thanks in advance.
Eman / Draftsman
Works at an Architects Company using ArchiCad 21
Intel(R) Core(TM) i5-6500 CPU @ 3.20GHz 3.19 GHz, 8.00 GB, 64-bit operating system, x64-based processor
insideru
It's polar vs x-y coordinates. Default shortcut slash ( / ).
Or go to tracker options, first item.
ARCHICAD 28 INT
macOS Sequoia
insideru
ARCHICAD 28 INT
macOS Sequoia
Eman
Hi insideru, thanks very very much
Eman / Draftsman
