Very basic question on exterior walls.
I just need some opinions. Is it better when working with exterior walls to have one wall continuing through all floors or have seperate walls on different slabs.
3 Replies 3
Rafal SLEK
Better choice is one wall for whole building option. If this wall is not simple you could easy model profiled wall.
Best
Rafał
//Archicad since 4.1 version
//MacBook Pro Retina 2019/2.4 GHz/Intel Core i9/32GB RAM/Radeon Pro 5500M 4GB/macOS 13.6
//Razer Intel i9/2.5GHz/32GB/Nvidia RTX 3080/Windows 11 Pro
//ArchiCAD Collaborate
depends on what you're doing really...
i like one piece walls where i have no windows, same material, etc but when more stuff comes along like windows, then i like the floor to floor option...
how long is a piece of string?
I prefer to have separate walls for each floor.
I think this makes it easier to work on each floor plan but then I started Archicad before multi-storey walls were around.
The big benefit of a multi-storey (continuous) wall is for when you want a window or opening that spans between floors or if you need an inclined wall.
