2004-03-03
		05:33 AM
		2024-05-03
		01:45 PM
			Aruzhan Ilaikova
2004-03-03 09:45 AM
2004-03-03 07:08 PM
2004-03-03 08:56 PM
icupat wrote:A quick P.S. to Dwight's excellent suggestions: you will probably want to make the slabs thick enough that you can use solid element ops to get the other effects that you want. For the tunnels, just subtract very fat rafters (you can control the angle of the rafter objects). If the underside of the stands matters and is exposed as a smooth, sloped/curvy surface, use the Profiler add-on (search this forum for more info) to create a swept object with the proper shape and subtract that from the collection of slabs. Railings (non-parametric) can be easily done with Trussmaker.
2. I haven't messed around with this much, but the only solution for the "vomitories" (the tunnels from the concession area to the stands) I've found is to use a landing and stairs again. Is there an easier way?
