We value your input!
View Hidden Lines in the Elevation Viewport
As of my tries to publish my elevations to pdf, I want to view my elevations in hidden line mode, and wanted to know how can i do that.
thanks
10 REPLIES 10
David Maudlin
Jet:
You can go to the 3D Projection Settings..., and click on the Parallel Projections... button to set up an elevation view for the 3D window so you can use the Hidden Line mode for the elevation, then place this view on a layout sheet (or print to PDF directly from the 3D Window). But I don't see what advantage this has over using the Elevation Tool to set up an elevation view of the model.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
David,
Thanks, You've helped me very much! the point of viewing Elevations in hidden line is only for publishing my elevations.
I don't want to print the walls as gray blocks, i want to print only the contours of the elements, as in hidden line mode.
if there's an option of publishing the elavations which were created by the elevation tool in hidden lines, it would be the best solution for me.
Is there such an option?
thanks
TomWaltz
I thought there used to be something in the hidden "Special Menu" that let you show hidden lines, but I never tried it.
Tom Waltz
Thomas Holm
Isn't this what you want? (Elevation settings)
Thats exactly what i was looking for! Thank you very much my friend, you've made my life easier
Thomas Holm
Hey Guys,
How do you show the hidden roof lines on an elevation?
I have a Skillion roof with a Parapet on 2 sides and would like to show the dashed lines to the roof location and slope.
Thanks
Myles
Also how do you show the window and door markers?
Thanks
Myles
Myles wrote:
Hey Guys,
Thanks
Myles
Unfortunately, Archicad does not have this feature of showing hidden lines in Elevations (or in 3D for that matter). So you would have to add this drawing information manually.
