View Map Items Disappeared
Has anyone had any issues with the items in the view map disappearing? The project map and layout book show everything but the view map is blank. I can access my view map items going to the layout book and opening the drawing by using "Open Source View."
Are you working in Teamwork?
We are working in Teamwork. We also are using the Cadimage plug-in.
Yes, we had the same problem. It is a known issue. See thread below
archicad-talk.graphisoft.com/viewtopic.php?t=46896
Katalin's advice was to contact your local re seller and maybe refer them to the thread from the link. They were able to sort this out for us pretty quick with a specific fix.
Hope that helps
