mukster
View Map
I took a day off, and for some reason my view map is minimized and I can't get it back up. How do I doing it to the front?
CosminF
You might want to re-load your work environment if you have one saved, or reload the standard one by going to Options - work environment and choosing from there.
https://support.graphisoft.com/hc/en-us/articles/18839486501009-Work-Environment-reset
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
As Cosmin said re-load a work environment.
Or go to the Window menu > Palettes and turn on the Organiser or Navigator (which ever one you prefer).
Also keyboard shortcut (F10)/
