2005-02-17 10:38 AM - last edited on 2023-05-25 06:21 PM by Rubia Torres
2005-02-17 03:46 PM
2005-02-17 03:53 PM
2005-02-17 04:18 PM
2005-02-18 03:15 AM
I will often do this with two walls, one on top of the other. The upper wall that contains the window I put on a 3d only layer that is only turned on in 3d view
2005-02-18 08:43 AM
2005-02-18 10:46 AM
Stress wrote:Click on the Quote button ... upper right
An off topic question ...... how does one get a previous post to quote with the authors name above....i.e. : "Stress co. wrote:" etc.
2005-02-18 04:30 PM
The transom window (in the hidden wall) still appears in your window schedule, right? How do you get the window "callout/#" in the plan view? Are you simply adding 2D text?It probably depends on how you do your window schedules. In my case I use the interactive schedule and you just have to make sure the "hidden wall" layer is included in the layers that the schedule looks in. Labeling is another issue and in this scenario it would need to be 2d text. I just had another thought for a work around that might solve the problem. Suppose the upper wall and window used a pen # that is set to white in plotmaker and was "sent to the back" such that the wall with the door was in front. I personally have a pen in Archicad that will show in Archicad but is defined with a white pen in plotmaker. I have not tried this but perhaps this would solve some of the the other issues (like labeling).
2005-02-18 05:34 PM
2005-02-18 05:42 PM
